Distillation Bubble Cap Tray Design
Started by , Apr 07 2008 04:53 AM
12 replies to this topic
Posted 07 April 2008 - 04:53 AM
Hellow all,
This is my first enginnering assignment to suggest modification in tray design. Conventionally we are using Bubble cap trays. As we know they are costly than sieve or valve trays but the they possese good turndown, which is important for us.
I am not getting from where to start. Whether i should reduce downcomer area, or reduce tray spacing, or increase slot area.
Can anybody advice me which way to go and why?
How can i take help from Hysis or Chemcad or i need to look for other softwares.
Posted 07 April 2008 - 06:43 AM
Dear,
You can use the tray sizing utility in Hysys for the perticular tower. You have to modes in Hysys one is to design and other is rating. You can select the Bubble cap trays and check for the results. In design mode you have options to vary the Tray Spacing and the Wier height.
Posted 07 April 2008 - 08:47 AM
Mj4u,
I am not sure how much you know about tray hydraulics, so my suggestions will be a bit general.
First of all do you have the design point for the bubble cap trays? ie. do you have the design loads, the jet flood the tray was designed for, the maximum allowed downcomer backup allowed? and do you understand the meaning and importance of these terms? If your design point is quite close to the maximum allowed values for these parameter, then we may have a bit of problem. I'll explain this with a small example, let us say you you reduce the downcomer area, now if the new downcomer area is too small then froth that is fed to the downcomer may not separate. This will result in what is called downcomer flooding.
Next, how critical is the turndown for you? Is is absolutely necessary to be met? If not then you can probably look at floating valve trays (the V-1 series by Koch-Glitsch).
Have you thought about changing the pressure of the column? This will change the vapor-liquid traffic and affect the hydraulics.
abhishek
abhishek
Posted 07 April 2008 - 10:40 AM
It looks like you didn't tell us what is the basis for tray modification requirements: without knowing this information, no one of us is able to give you any advice or guidance in this subject. This should be the minimum input data from your side: whether the column is lacking of hydraulic capacity, separation efficiency, or tower operating conditions and/or feed type have been changed. Before you start any work in tower internals revamp, I'd suggest you to get the answers on these questions. Otherwise, you will be wasting your time for nothing.
What kind of tower is it, and what is the application? Have you performed any analysis of actual column operation? What are the targets of internals modification?
Good luck,
Good luck,
Posted 08 April 2008 - 05:54 AM
on this subject go to
http://www.kolmetz.c...gpaperfinal.pdf
maybe it can be useful
Best regards
Luis Marques
Best regards
Luis Marques
Posted 10 April 2008 - 12:22 PM
My two cents worth - Though I use general purpose process simulators all the time, and they are wonderful tools for process engineers, I don't trust them at all when it comes to tray (or packing) sizing. I greatly prefer to use the vendor's own software for their equipment. Of course, if a licensor is involved, they should be even better aware of the best approach to use.
Doug
Doug
Posted 10 April 2008 - 11:32 PM
Dear djack77494,
I have Hysys and Chemcad with me but in our case are the technology providers ao i dont have any licensors software available with me.
Previously i was involved in process development and not in enginnering assignment as this. So as a newcomer i wish you gyys will help out me in this.
Posted 11 April 2008 - 11:32 AM
If you know why these bubble-cap trays need to be replaced, then you'll probably don't need any licensor software.
As I have said in my previous post, knowing the reason for tray revamp will save you a lot of time and efforts.
Best regards,
Best regards,
Posted 12 April 2008 - 06:18 AM
Thanks Zauberberg
#10
Posted 15 April 2008 - 04:10 AM
Thank you Abhi,
As you rightly said i am not expert in this area. can you just tell me from where i can get more information about the trays mentioned above.
#11
Posted 15 April 2008 - 10:40 AM
you can use FRI,it can calculate the tray very well.
#12
Posted 15 April 2008 - 08:30 PM
Well you can contact any of the tray vendors. Koch-Glitsch and Sulzer are quite popular ones.
abhishek
abhishek
#13
Posted 16 April 2008 - 07:55 AM
QUOTE (abhi_agrawa @ Apr 15 2008, 04:30 PM) <{POST_SNAPBACK}>
Both should readily and at no cost supply you with their own tray sizing software, assuming you are a likely (or at least potential) tray customer.
Petrosim Tray SizingStarted by Guest_tomr91_* , 27 Feb 2025 |
![]() Heat Exchanger Network DesignStarted by Guest_Kakashi-01_* , 21 Feb 2025 |
