I am designing a compressor system. The compressor will be used to supply consumers with 300bar Hydrogen. The existing compressors that we have are reciprocating compressors which take in hydrogen at 200mbar = 20 kPa in the first stage. The compressor is a 5 stage piston compressor. The system will comprise of a knock out pot, filters with dp cell, accumulator and a kickback to the knockout pot. The pressure control will be based on the kickback line i.e. if there is no consumption of hydrogen then the kickback will recirculate the hydrogen in the system with a solenoid valve on the main hydrogen supply line closing. My question to those who have this sort of design experience:
1. Do i need an expansion vessel? Will the knock out pot be sufficient as an expansion vessel in addition to a the solenoid valve which closes the main hydrogen supply to the system when it sees a high pressure in the KOpot. I also have a concern with the relief valve on this vessel which will be set to 25kPa. I am afraid the relief valve will constantly pop. Do i have anything to fear. Should I put in an expansion vessel in which the kickback at 300 bar feeds into.
2. I need to tie the relief valve line on the knockout pot into the flare system but due to the low pressure release I will definately have problems with the backpressure of our flare system. The flare system was designed for a backpressure of 50kPa. I could vent but that will not be safe especially during lightening. What do i do? I could size the relief valve for a back pressure of 50kPa but I am not sure whether that would be the correct way to go about it.
The flowrate of hydrogen to the compressor will be 20 kg/hr.
It would be greatly appreciated if anyone could assist. Thanks
