Threadolets Welded On Pipe
#1 Andree
Andree
  • 140 posts
Posted 13 May 2008 - 07:33 AM
Does anybody know if small threadolets (G 1/4" BSPT female) can be welded on 1 1/2" pipe?
I read somewhere that threadolets are recommended for "big" pipes or vessels (however it wasn't explained what notion "big" means), hence my concern.
And I also wonder if this is good engineering practice to use threadolets fitted to small piping or other solution is recommended to install for example pressure transmitter on pipe.
A.
Posted 13 May 2008 - 01:19 PM
Andree:
A “threadolet” is a quick and easy access to a flow stream. But it has its inherent liabilities.
By design, it is intended to be welded onto a flow pipe by means of using a fillet-lap weld. This is the weakest weld available in the boilermaker / pipefitter industry. As a welder, I always have always stayed away from this type of weak welding technique when dealing with process (or utility piping or vessels). I always insist on a “full-penetration” weld technique – which is a type of “butt-weld”. This type of weld ensures that the introduced joint is not a “weak link” in the chain – so to speak.
The technique of applying a threadolet is by simply laying it onto the main pipe and welding a fillet bead around its outer periphery and subsequently drilling a hole through the threadolet nozzle, attaching a pressure gauge or whatever to the threaded nozzle. This works for low pressure piping applications – for a while. What you have done, when you follow the above procedure, is that you have created a much weaker pipe wall at that junction and, as if that wasn’t enough, you have also introduced a stagnant, corrosive site directly under the threadolet’s “saddle”, where it rests on the outer pipe’s surface. This site is subject to static fluid and is a candidate for increased corrosion – at a point in the pipe where you have purposely weakened it! That, in my opinion is not too swift. I have always out-lawed the use of threadolets in all plants and operations that I have operated or managed.
If you are dealing with a 1-1/2” line, simply cut it with a band saw and butt-weld a reducer tee at that junction.
#3 Andree
Andree
  • 140 posts
Posted 14 May 2008 - 09:52 AM
Art,
Thank you for your comments.
I fully agree with your suggestions about advantages of butt welding for high pressure application.
However, I will operate at not very high pressure (max. 7 bar) and just wondered if this is possible to weld 1/4" threadolet (which has about 1" at the "base") on 1 1/2" pipe (about 1 7/8" OD). I think that it should be some special shape threadolets suitable to given size of a "run pipe".
I didn't find standard reducer tee 1 1/2" to 1/4" to fit my pressure sensor (max. reduction 1 1/2" to 1/2"). Hence, I started thinking about threadolets - it is quick, easy and for low pressure application should provide reasonable streangth... The increased corrosion problem is however inavoidable in this case...
A.
