Gas Compressibility Factor Calculation
#1 HMAlmosa
HMAlmosa
  • 9 posts
Posted 22 May 2008 - 12:39 AM
Do you know of a formula that I can insert in Excel to calculate gas compressibility factor. I have looked in many places, but could not find one. I finally developed a complicated formula through curve fitting the compressibility factor charts in GPSA as a function of reduced pressure and temperature (Pr & Tr). Can you help with this one?
#2 latexman
  • 1,849 posts
Posted 22 May 2008 - 07:58 AM
There must be dozens of Equation of States (EOS) you could use to estimate Z. The van der Waals equation is simple and general. The most widely used two parameter Equation of State is the Redlich-Kwong equation. Check in your MEB and thermo textbooks, Perry's Handbook, and Sherwood, Reid , and Prausnitz.
#3 joerd
joerd
  • 371 posts
Posted 22 May 2008 - 08:50 AM
There's even one on this site: www.cheresources.com/srk.xls
#4 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 25 May 2008 - 08:18 AM
Please look into the following thread where I have posted an excel sheet to calculate the compressibility factor Z :
http://www.cheresour...?showtopic=4731
Ankur
#5 iceman
iceman
  • 11 posts
Posted 28 September 2009 - 05:54 AM
The best method is as you mentioned using reduced pressure and temperature. Then finding the compressibilty factor from charts. The reason being the charts have been built using experimental data i.e more accurate than any method for calculating the factors. Usually this is straight forward once you know the Tr/Pr values with final aim being of calculating the volume of a real gas. It gets a little bit involved (but only just that) when trying to find the pressure or temperature of a known volume of a gas. Then as you mentioned you end up with an equation of the type
Z= K x P or Z= K x T where K is a numerical figure obtained from setting up the equation.
Plotting this in the experimental chart and finding your pressure or temperature at the intersection of this plotted straight line through the origin with slope K with the Z curve of either the known pressure or temperature as the case may be. Assuming either the pressure ot temperature is unknown then V,n,T,R are known and the equation becomes as above.
I hope this of some benefit and if known then at least to confirm it.
regds
iceman
#6 breizh
  • 6,810 posts
Posted 04 October 2009 - 03:26 AM
In case you need more input :
http://www.cheng.cam...hermo/pure.html
regards
