Is there a relationship or link between a fluid's viscosity and density? Explain?
Relationship Between Viscosity And Density
Started by cornflict, Jun 04 2008 03:52 AM
Posted 04 June 2008 - 03:52 AM
Posted 05 June 2008 - 09:59 AM
QUOTE (cornflict @ Jun 4 2008, 12:52 AM) <{POST_SNAPBACK}>
Simple answer is NO. The two are totally independent. You can have low or high density liquids that have low or high viscosities. There is no correlation between the two.
Posted 06 June 2008 - 08:02 AM
QUOTE (cornflict @ Jun 4 2008, 04:52 AM) <{POST_SNAPBACK}>
Hi Cornflict,
While absolute viscosity and density are independent properties, you may encounter use of kinematic visccosity which is by definition the ratio of a fluid's viscosity to density.
You can see an explanationhere:
http://www.engineeri...sity-d_412.html
Ali
Understanding Polytropic Head And Its Relationship With Gas DensityStarted by Guest_Kakka_* , 18 Dec 2024 |
Negative Sign In Newton's Law Of Viscosity?Started by Guest_Cheeky_* , 24 Oct 2024 |
Viscosity CalibrationStarted by Guest_waheed2020_* , 11 Dec 2022 |
Finding The Density Of A CatalystStarted by Guest_Rachel Tee_* , 23 Feb 2021 |
Density Delta Between Water And OilStarted by Guest_CHEMSTRONG_* , 10 Mar 2022 |
