For a pump in existing system how to measure the developed head across it.
Is it the diffrence beteween suction & discharge PG readings. please clarify.
How To Measure Developed Head Of Pump
Started by babulala, Jul 25 2008 01:22 AM
Posted 25 July 2008 - 01:22 AM
Posted 25 July 2008 - 08:24 AM
Dear,
You are right the differential pressure in a centrifugal pump is nothing but the Discharge Pressure minus Suction Pressure. Now you can convert this to head by using the density of the fluid.
Posted 25 July 2008 - 09:45 AM
Pumps developed head has both pressure & velocity components.(sqr(velocity)/2g)+diff head across the pump.mr.padmakar is correct but in as i feel only in shutoff condition the difference in PG of suction & discharge can give fully developed head of the pump as there is no flow (Velocity=0).
Posted 25 July 2008 - 02:00 PM
QUOTE (man2k @ Jul 25 2008, 05:45 AM) <{POST_SNAPBACK}>
The true pump developed head would also be obtained if the suction & discharge pipes were the same size and pressure gauges were mounted in each. More often than not, however, this is not the case, and a correction for the difference in velocity heads should be incorporated into the calculation.
Esp Or Sro PumpStarted by Guest_sima-f_* , 05 Jan 2025 |
Understanding Polytropic Head And Its Relationship With Gas DensityStarted by Guest_Kakka_* , 18 Dec 2024 |
