Hi!
My boss just asked me to find out whether the frozen condensate in a vessel will melt when you put metanol at room temperature inside. Thats all the information I've got.
Please help me, because I'm not sure about this and don't want to tell him something wrong.
Methanol And Water
Started by kalovon, Aug 29 2008 04:29 AM
Posted 29 August 2008 - 04:29 AM
Posted 29 August 2008 - 08:11 AM
QUOTE (kalovon @ Aug 29 2008, 05:29 AM) <{POST_SNAPBACK}>
Hi!
Take a look to this:
Freezing Point of methanol alcohol mixed with water
Take your Methanol \ Water Mixtures Conctrate to determen the freezing point of your mixture. Winter is here and you should make sure your not going to have a freezzig problem.
Methanol (METHYL ALCOHOL) Conc.
Vol.% ---Freezing Point,F ---Flash Point,F
0----------32f--------No Flash
13---------20f --------130f
24---------0f ---------110f
35---------15f---------95f
46 --------40f---------85f
56---------65f---------75f
66---------95f---------70f
75---------115f--------60f
83---------125f--------55f
92---------130f--------55f
100--------144f--------55f
Other tid bits
Boiling Point: 147F,64C
Melting/Freezing Point: : -144F,-98C
Vapor Pressure: 760 Vapor Density: 1.1
Specific Gravity: 0.8
another information ,
physical properties methanol:
Methanol is a colorless liquid, completely miscible with water and organic solvents and is very hydroscopic. It boils at 64.96° C (148.93° F) and solidifies at -93.9° C (-137° F). It forms explosive mixtures with air and burns with a nonluminous flame. It is a violent poison; drinking mixtures containing methanol has caused many cases of blindness or death. Methanol has a settled odor. Methanol is a potent nerve poison. Key physical properties are:
Melting Point : -97.7 0C
Boiling Point : 65 0C
Relative Density : 0.79
Formula: CH3OH
Molecular weight: 32.042 kg/kmol
Heat of Formation -201.3 MJ/kmol
Gibbs Free Energy -162.62 MJ/kmol
Freezing point: -97.7 °C
Boiling point: 64.6 °C (at atmospheric pressure)
Critical properties:
Critical temperature 512.6 K
Critical pressure 81 bar abs
Critical volume 0.118 m³/kmol
Liquid Properties:
Density 791 kg/m³ at 20 °C
Heat of Vaporization 35278 kJ/kmol
Viscosity:
a = 555.3 b = 260.6
where log(viscosity) = a * ( 1/T - 1/b )
viscosity: mNs/m² T: °K
Vapor Properties:
Heat capacity:
a = 21.152 b = 0.07092 c = 2.59E-05 d = -2.85E-08
where Cp = a + b*T + c*T² + d*T³
Cp: kJ/kmol.K T: °K
Vapour pressure:
a = 18.5875 b = 3626.55 c = -34.29
where ln(P) = a - b/(T+c) P: mmHg; T: °K
within range -16 to 91°C
hope these information will help you
Posted 29 August 2008 - 01:11 PM
No, the condensate will not melt. Methanol is freezing inhibitor if you mix it with water prior to cooling/chilling. Once when ice is formed, methanol will not help.
The same applies for hydrate inhibition in natural gas processing: injection of hydrate inhibitor should be provided prior to hydrate/ice formation point, and definitely not after.
Water Hammer In CondenserStarted by Guest_Ahmadhamzahperta_* , 31 Oct 2025 |
Pem Water ElectrolysisStarted by Guest_tomr91_* , 29 Jul 2025 |
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Steam Sparger In Atmospheric Water TankStarted by Guest_owe_* , 16 May 2025 |
