Gas Pipeline Pigging
Posted 07 September 2008 - 02:47 AM
I'm trying to put together a spreadsheet to help estimate when a gas cleaning pig will arrive in the receiver given real time flowrates, pressures, and temperatures.
Thanks for the help--
Posted 08 September 2008 - 12:43 PM
Posted 08 September 2008 - 02:49 PM
Superficial velocity of the fluid... generally about 3-5 m/s...
Posted 08 September 2008 - 04:34 PM
Posted 09 September 2008 - 07:57 AM
You may use the following link to access the paper "Numerical Simulation of Pig Motion through Gas Pipelines" as your reference. It is NOT as simple as V=S/T.
http://espace.uq.edu..._afmc_16_07.pdf
Shan
Posted 04 July 2009 - 07:18 PM
Dear all,
How can we estimate the slug volume in the front of pig? Should we calculate all liquid in front of pig for all pipeline length?
Rgds,
Fachri
Posted 15 October 2009 - 08:30 AM
Doe anybody have an effective method for estimating the time it takes for a pipeline cleaning pig to travel down a length (~60km, 38") of a gas pipeline?
Try this spreadsheet..you will need to add your own factors for the pig..mass, friction etc..
Posted 15 October 2009 - 11:48 AM
Determining Pipeline Design PressureStarted by Guest_applepe_* , 05 Dec 2024 |
![]() ![]() Energy Saving In Pump By Reducing Pressure Drop In Downstream PipelineStarted by Guest_Srinivas Agastheeswaran_* , 19 Nov 2024 |
![]() ![]() Steam Condensate Pipeline Water HammerStarted by Guest_kaidlut_* , 06 Sep 2024 |
![]() Achieving Ultra-Low Water Content (<0.1 Ppmv) For Pipeline PiggingStarted by Guest_Finchh_* , 21 Aug 2024 |
Pipeline Material SelctionStarted by Guest_BabRafiq1_* , 06 Sep 2022 |
