hi does anyone know what can i use to size a gas buffer tank. Thanks.
Gas Buffer Tank Sizing
Started by eridegu, Sep 09 2008 02:38 AM
Posted 09 September 2008 - 02:38 AM
Posted 10 September 2008 - 09:23 AM
eridegu,
You are very vague, please be more specific.
One example that comes into my mind is the Accumulator in the discharge of an air compressor with intermittent operation. It is sized based on a certain number of start-ups per hour of the compressor(vendor information) and air consumption at accumulator outlet. This is what you are referring at?
