A friend of mine, as part of her practical training as a chemical engineer needs to reduce the power consumption of a centrifugal compressor which is used to compress syngas in a gas loop. Now I'm a computer engineer, and while I understand the basic workings of the compressor, she is expected to reduce the power consumption by reducing pressure drops along the discharge side of the compressor. The chem eng aspect of this is what I'm not too familiar with. I would appreciate some ideas or guidelines with respect to this.
As I've stated, the gas being compressed is syngas. The suction pressure on the compressor is 19bar and the discharge pressure is 25bar. The compressor is being driven by an electric motor. One idea she has is to look at a globe valve that's being used in the gas loop. Apaarently, the pressure drop across this valve is big, and she wants to split the gas stream and use a bypass over the globe valve. Is this a recommended approach?
I was also thinking about pressure drops due to elevation in the piping, or changes in temperature? I'm not sure though, as I've said, my expertise is in programming
If the compressor is being driven by an electric motor, could a gearbox or belt drive with a different ratio be introduced?
Any other suggestions welcome. or if you need any other information, I can obtain it for you.
Thanks in advance
Dhiren
