I would like to know the types of check valve and orientation of Check valve whether its is placed horizontal or vertical in refinery.
Thanks in Advance.
Orientation Of Check Valve
Started by anshumanag, Dec 15 2008 07:05 AM
Posted 15 December 2008 - 07:05 AM
Posted 15 December 2008 - 10:20 AM
QUOTE (anshumanag @ Dec 15 2008, 08:05 AM) <{POST_SNAPBACK}>
Thanks in Advance.
Thanks in Advance.
Anshuman,
Check valves could be:
1. Lift type plug
2. Lift type ball
3. Swing type disc
4. Dual Disc
and various others. Check out the following weblinks:
http://www.apcovalves.com/which.htm
http://en.wikipedia....iki/Check_valve
http://www.spiraxsar...heck-valves.asp
Irrespective of whether it is refinery or petrochemicals check valves are preferentially provided in horizontal pipe runs. Only in exceptional circumstances and where there limitations of piping layout, check valves are provided in vertical pipe sections. As a general rule check valves in vertical pipe runs are avoided. Even in pump discharge lines feeding to a destination which is at a substantial elevation, a small horizontal run just after the pump discharge nozzle is provided which accommodates the check valve.
Hope this helps.
Need Help To Determine Axis Orientation Of Lithium NiobateStarted by Guest_Petek_* , 09 Feb 2025 |
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
