Hi there, I'm looking to make a flexible simulation so I need to figure out how to define a global real variable.
I want to be able to use this variable in places such as using a global variable to hold the value of the total molar flowrate of a stream going into a distillation column. I can then use this variable in such places as "distillate rate" when specifying distillation column operating conditions or specifying the bounds on a manipulated variable (such as the "varied" variable in a design spec).
How can I declare a usable global variable?
How do I do math on a declared global variable? Do I do it directly in the input field its used in?
Thanks a lot guys, I appreciate it.
How Do I Define A Global Real Variable In Aspen Plus?
Started by Guest_Shen_*, Jan 16 2009 06:29 PM
No replies to this topic
Guest_Shen_*
Posted 16 January 2009 - 06:29 PM
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
No Liquid Phase In Aspen PlusStarted by Guest_PengRobinson_* , 09 Feb 2025 |
![]() Help On Simulation Of Reactor In Aspen PlusStarted by Guest_m.ghaziasgar_* , 06 Jan 2025 |
