Dear All
We dilute fine particle slurry (in HC solvent) from about 10g/l concentration to about 5 g/l by batch process. I was thinking of making this process continuous using Static Mixers. As per the literature available on the net these mixers work very well for liquid mixing. I could not get any information on application of these mixers for slurry handling. Hope members can advise suitability of these mixers for handling dilute slurry (av. particle size about 100micron)
Warm Regards
Bhattu
Inline Static Mixers
Started by Guest_bhattu_*, Jul 15 2004 07:27 AM
Guest_bhattu_*
Posted 15 July 2004 - 07:27 AM
Posted 16 July 2004 - 02:03 AM
10 g/l is not that high a concentration. Unless this slurry has unusual rheological properties, I think that static mixers would be suitable for the task of diluting to 5 g/l.
Guest_MAW_*
Posted 01 November 2004 - 10:55 AM
My suggestion is to contact the Chemineer and/or Lightnin mixer vendors. The Kenics is an old tried and truc static mixer by Chemineer that will probably get the job done. Either of these vendors can easily design the mixer you need and have it to you within weeks. They are also willing to sign confidentiality agreements. The design is free. Hope this helps. M.
Converting A Static Simulation To Dynamic SimulationStarted by Guest_tomr91_* , 26 Feb 2025 |
![]() Static Simulation To Dynamic Simulation Of CduStarted by Guest_tomr91_* , 09 Jan 2025 |
Stagnating Vs. Static Pressure In Psv Inlet Line Pressure DropStarted by Guest_M Menessy_* , 20 Apr 2018 |
Ultrasound MixersStarted by Guest_shvet1_* , 10 Oct 2022 |
Static ElectricityStarted by Guest_Jaldhipatel_* , 04 Apr 2021 |
