Normal Cubic Meter (nm3) And Actual Cubic Meter (am3)
Started by Vish, Mar 03 2009 12:56 PM
8 replies to this topic
Posted 03 March 2009 - 12:56 PM
Dear all,
I just wannted to know, what is Normal cubic meter(Nm3) and Actual cubic meter(Am3)? What is their significance and where they are used? Specifically, why Nm3 is used in fan calculations and how it is calculated?
Posted 03 March 2009 - 01:09 PM
Hi There,
This is a very simple calculations involving basis gas laws, refer to any basis chemistry handbook for these kind of calculations.
Nm3 refers to gas volume occupied at normal temperature and pressures which are 0 deg c and 14.7 psia. Am3 refers to gas volume at actual operating conditions of the process. Use P1xV1/T1 = P2xV2/T2 for the conversion.
ARAZA
ARAZA
QUOTE (Vish @ Mar 3 2009, 12:56 PM) <{POST_SNAPBACK}>
Dear all,
Posted 03 March 2009 - 01:31 PM
Vish,
I have posted a spreadsheet SCFM_to_ACFM.xls on the forum which explains about actual flow for fans and compressors. Use the search feature of the forum to look for the spreadsheet, it is self-explanatory as regards to inlet flow of air to fans and compressors. The only difference is that it uses imperial units instead of SI units but the units can be converted by the user as per his or her convenience.
Posted 03 March 2009 - 01:51 PM
As discussed in previous threads, one should always mention the "standard" or "normal" conditions that are used, since these conditions prove not to be so standard or normal as their names suggest...
Posted 03 March 2009 - 01:57 PM
QUOTE (Vish @ Mar 3 2009, 06:56 PM) <{POST_SNAPBACK}>
Dear all,
Check out the following:
http://webwormcpt.bl...mtric-flow.html
Posted 03 March 2009 - 11:42 PM
Hi ankur,
I couldnt trace out the spreadsheet u were yalkin abt. Can u help me in finding that?
Posted 04 March 2009 - 01:04 AM
I think this part was not yet answered:-
"What is their significance and where they are used?"
I view the use of Nm3 as a communications tool to avoid any ambiguity.
We know that Volume of a given amount of gas varies with both pressure and temperature.
As pressure increases, the gas volume decreases. As temperature increases, the gas volume increases.
Suppose that an engineer is in need of a compressor that should compress 1000 m3/hr of air.
This statement is not sufficient for him to ask for a compressor.
Imagine the confusion that would occur if the compressor is required in Holland
where the ambient temperatures are very low while the compressor manufacturer is in Saudi Arabia
where the ambient temperature is quite high.
So, 1000 m3/hr at which temperature?
In order to avoid these ambiguities, it is specified at a clearly mentioned reference conditions.
Using the P1V1/T1=P2V2/T2, it is always possible to convert back to the actual conditions
that we are required to run the compressor.
So, for example, the compressor manufacturer will test the compressor at the actual conditions there
but will specify the results at the agreed reference conditions to avoid ambiguities.
Posted 04 March 2009 - 02:31 AM
QUOTE (Vish @ Mar 4 2009, 12:42 AM) <{POST_SNAPBACK}>
Hi ankur,
Click the following linkf for the relevant post. When you are using the search feature and you want to do a search for the entire forum then remove the tick mark for the sub-forum or do a general search for the entire forum. I would expect all our readers to be that much savvy to use the search feature in the manner best suited to their need.
http://www.cheresour...x...758&hl=SCFM
Posted 05 March 2009 - 03:33 AM
Just to add one more point. Take care of relative humidity when you are converting from ACFM to SCFM. As relative humidity changes so do volume of air too.
Please find attached conversion spreadsheet i got from one of compressor vendor.
Good luck...
Good luck...
Centrifugal Compressors (Actual Vs Polytropic Head)Started by Guest_panoska_* , 25 Oct 2024 |
Firewater Theoretical Vs Actual FlowStarted by Guest_stu_* , 25 Feb 2024 |
Low Pressure Air Flows Thru Orifice Meter Plate QuestionStarted by Guest_sfhh_* , 24 Feb 2023 |
Difference Between Estimated Stream And Actual StreamStarted by Guest_skyicetel1_* , 20 May 2022 |
Help! Translate Technical English To Normal EnglishStarted by Guest_anara8_* , 17 Nov 2021 |
