Posted 04 March 2009 - 06:59 AM
Shar:
There is nothing that you can do to “re-rate” a positive displacement pump from a process standpoint. And from a practical, mechanical standpoint there is little you can do except perhaps reduce the rpms.
The usual thing that is done (and I’ve done this countless times with gear and vane type of PD pumps) is to disassemble the pump and check out all the clearances and its physical condition. In a PD pump it is the clearances that make or break the successful operation of the pump. If the wear is significant, it is then a matter of reconditioning the working parts or replacing them. Many times, if your location and working conditions warrant it, you can totally recondition the pump. In the USA and other so-called developed countries, the cost of labor is so high that the replacement of the pump with a new one is the most economic option.
If you plan to reuse an old pump, you should disassemble it and check it out internally. A bench capacity test should also be done to verify its performance. If the pump passes those tests, it should be ready to work.
