Hi all,
I am in desperate need of expert guidance. I am designing a scrubber/absorber for HCL and SO2 removal. I want to use a lime slurry for this purpose but am confused as to which type of slurry to use, CaCO3 or Ca(OH)2?? Also once i have decided upon the type of slurry, do i use a packed or plate column ( i have seen both types used in industry)? I guess plate would be more appropriate as this would prevent clogging problems associated with packed absorbers. How do i go about designing the absorber in terms of height and diameter? I have looked at several sources with varying success but i am not sure which equations to use.
Any help would be greatly appreciated as university tutors are not very forthcoming with advice
Removal Of Hcl And So2 From Waste Incineration Flue Gas
Started by mirzaf, Mar 16 2009 01:56 PM
No replies to this topic
Posted 16 March 2009 - 01:56 PM
Smr Reformer Flue Gas FlowStarted by Guest_kaidlut_* , 14 Feb 2025 |
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
![]() Moisture Removal From Blower AirStarted by Guest_Makarove_* , 12 Jul 2024 |
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Co2 Removal Membranes Between Compressor StagesStarted by Guest_Sinclc_* , 26 Mar 2024 |
