Instrument Air Consumption Calculation
Started by sina, Apr 28 2009 05:10 AM
7 replies to this topic
Posted 28 April 2009 - 05:10 AM
Hi all!
I work on one refinery unit project.
To my instrument air subheader is attached 5 tubings 1/2" and each supply 5 control or on/of valves.
All together, that is 20 valves on one subheader.
Now I must make one document with air consumption calculation.
For now I don't have manufacturer or model of the valves.
It would be a great help if anyone has that document (or template) just to see how it looks like, what it contains and what are the formulas for calculating consumption.
PLEASE HELP!!!
PLEASE HELP!!!
Posted 28 April 2009 - 05:15 AM
First, you will need to know the size of the valve, more specifically, the size of the actuator. For the on/off valve it is a simple calculation of how often the valve cycles and the volume of the actuator. For the modulating valves, it is tougher, because usually they move only a portion of the travel.
One way to get around this is to do a 'thought' experiment. You take the output of the control device (either solenoid, positioner, 3-15 controller, etc.) and use this as a max air flow. Then you try to figure out how many valves will be actuating at any specific time, this will give you a calculated instantaneous maximum air flow in the line.
Posted 28 April 2009 - 06:38 AM
Hi Sina,
Normally there are three ways to calculate or estimate instrument air consumption. For brownfield jobs, you need just to retrieve pressure trend of instrument air receiver and volume. For greenfield you should use vendor data for continous and intermittent users such as control valves shut down and blowdown valves.
In absense of vendor data, you should use rule of thumbs for each type of users. I have recently done a similar calculation for Shell. In case you can not find any resource, flag up. I will try to give you a sample.
In total instrument air capacity take care about simultanous users. In refinery applications you can not just list out users and do sum.
Cheers,
Majid
Cheers,
Majid
Posted 28 April 2009 - 11:54 AM
Sina,
Have you tried using the search feature of the forum? There are many posts on instrument air consumption discussed in great detail on the forum. Newcomers, please use the search feature of the forum as time and again I have been telling that the majority of the queries you have, have been dealt earlier on the forum and it has been observed that at least 70 to 80% percent of the queries are repetitive in nature.
Just for this time, I am giving a link for an older post which has discussed instrument air consumption in great detail. Have a look at this:
http://www.cheresour...__1
Edited by ankur2061, 27 April 2010 - 11:10 AM.
Posted 24 April 2010 - 10:17 AM
mr.Majid
can you give sample calculation thank you
adi
adi
Posted 25 April 2010 - 10:30 AM
Normally, 2 NMC/hr of instrument air is a safe estimate to start with.
Imran Idris
http://forums.thepetrostreet.com
Imran Idris
Edited by imran.idris, 25 April 2010 - 10:30 AM.
Posted 25 May 2010 - 01:53 AM
Mr, Majid,
Please send me sample computation to makkee8@hotmail.com
Thanks in advance.
makk
Thanks in advance.
makk
Posted 25 May 2010 - 05:36 AM
Hi
Attached file will help you.
Edited by sheiko, 27 February 2011 - 12:31 PM.
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
Hydraulic CalculationStarted by Guest_applepe_* , 06 Oct 2024 |
