Hi all,
Can some one tell me why a tapping (Branch Connection) from a header line should be taken from the top(for liquids) and from the bottom(for gases)?
There are many answers like drain points, venting out and all. But is there any exact logic behind this.
Further to that Compressed air(Utility) comes under which condition?
Thanks a lot for your advices. I owe a lot to you all for sharing this valuable knowledge here.
Nag
Tapping (branch Connection) From A Header
Started by Nageswar Kotari, May 28 2009 05:23 AM
Posted 28 May 2009 - 05:23 AM
Posted 28 May 2009 - 06:03 PM
QUOTE (Nageswar Kotari @ May 28 2009, 06:23 PM) <{POST_SNAPBACK}>
Hi all,
Nag
Nag
As an example , consider dirt ( particles, rust, chemicals ,...) settling at a bottom part of a header during a shut down and when you want to restart if piped underneath a header , big chances for pluggages.
Posted 29 May 2009 - 08:55 PM
I would prefere for both vapor branch and liquid you definitely should take from the top. Consider the dirt that may entrained and result in headache for our equipment.
but for two phase flow, like wet steam for instance, I would prefer using impact tee, it will resulting in equal phase splitting.
Nag[/quote]
[/quote]
Nag[/quote]
[/quote]
![]() Psv Sizing On Condensate HeaderStarted by Guest_nabeelsp1036_* , 22 Jun 2023 |
Flare Header PressureStarted by Guest_ali99_* , 07 Sep 2022 |
Vent HeaderStarted by Guest_TheChemEng_* , 21 Aug 2021 |
![]() How To Determine The Size Of Header ?Started by Guest_steptacular_* , 30 May 2018 |
