This is regarding a new reciprocating compressor installation which is already piped up and in place as per the attached pdf file. I am trying to evaluate if the current piping arrangement, control valves and other control instruments are sufficient for the safe and stable start-up and operation of this compressor.
This is 2.7 MMSCFD recip compressor on an FPSO with suction pressure of 8.5 bara and discharge pressure of 20 bara. The produced gas from the gravity separator is almost always more than 2.7 MMSCFD and the excess gas is flared. In case of lower production of gases, the capacity control line (or the recycle line) is to be used to control the suction pressure.
The problem that has been realized in the current design is that the flaring of the gas is possible only from the suction KOD and therefore suction KOD always need to be in service even if the compressor is not operating. i.e., if we want to operate the gravity separator to continue oil production without running the compressor, we need to keep the suction KOD in service, to be able to flare the produced gases.
The compressor vendor requires that there should be a new line from upsteam of SDV-2 to the flare to isolate the suction KOD from gravity separator. The current line from suction KOD to flare will not be required in that case. As the system is already built, I am trying to find out if it is possible to start/up and operate the compressor that way it is right now, or by making minimum possible changes.
I am looking for suggestions for a startup procedure and control philosophy to achieve this objective.
Your recommendations are highly appreciated.
