Bog Rate Of Lng Tank
#1 winanto
winanto
  • 6 posts
Posted 19 August 2009 - 04:23 AM
Many reference, design or textbook said that Boil-off gas rate of LNG tank shall be 0.05%/day.
Could you explain what is the background/consideration?
How was it selected as design basis? Is there any international agreement?
Thank you.
#2 Zauberberg
Zauberberg
  • 2,728 posts
Posted 30 August 2009 - 11:59 AM
Are you speaking about LNG carriers or LNG tanks in onshore plants? The principle of operation of both systems is quite a bit different - e.g. in carriers there is average heat gain that generates BOG and provides self-refrigeration of the system, whereas in LNG plants there are other factors that contribute to BOG generation: LNG production rate (tank inflow), last Methane flash stage pressure (= temperature of LNG going to the storage), ship cooldown/loading (tank outflow) etc.
#3 Zauberberg
Zauberberg
  • 2,728 posts
Posted 31 August 2009 - 11:21 AM
Here are some materials that may be of interest to you:
#4 winanto
winanto
  • 6 posts
Posted 01 September 2009 - 08:35 PM
Dear,
I mean is the BOG rate based on heat leak to tank only, for on-shore LNG Tanks.
I read some references, that up to now the average generated BOG is around 0.05%. Is the limitation is material to build tank? Is is possible to select other material to reduce the heat leak?
#5 Zauberberg
Zauberberg
  • 2,728 posts
Posted 02 September 2009 - 11:01 AM
Tank heat gain is just one of the factors contributing to BOG generation. These include:
- LNG transfer/loading pump(s) heat gain
- LNG flash vapor
- Piping heat gain
- LNG vapor displacement (tank inflow)
- Ship vapor displacement (ship vapor return)
- Ship vapor return line heat gain, etc.
Below is attached the design document for one of LNG plants, showing BOG generation summary.
