Can the ejectors (steam or water)be used for pumping water from vacuum tanks that is being maintained at 0.2 bar(a)?
elaborating the above question:
I need to pump water from Hotwell tank to the storage tank (maintained at atmospheric pressure), The Hotwell tank is maintained at a pressure of 0.2 bar(a).
Can I use ejectors(using steam or liquid as motive fluid), (by having a suction lift) for pumping water from hotwell to storage tank?
Do the NPSH calculations apply for these Ejector systems?
thanks,
Edited by chemic, 27 August 2009 - 01:35 PM.
