We are evaluting relief devices for half pipe jackets on our tanks. The typical case of two phase flow of a liquid filled system results in a large device even though there is little actual quantity in the jacket.
We have adjusted for the insulation but still end up needing an "E" or "F" orifice depending on the set pressure. When we ignore jacket insulation, the size of the device becomes absurd considering the half pipe jacket is only a 3" or 3.5" OD.
Who else is struggling with high calculated values? The calculation methods only look at surface area and no account is made for the fact the jacket has very little volume and the coiled half pipe is more akin to a piping system than a "pressure vessel."
tia,
Tom
Half Pipe Jacket Reliefs
Started by Guest_Tom_*, Jun 09 2003 01:23 PM
No replies to this topic
Guest_Tom_*
Posted 09 June 2003 - 01:23 PM
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
![]() Pipe Entrance And Exit LossesStarted by Guest_katmar_* , 13 Nov 2024 |
![]() Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
![]() ![]() Reciprocating Pump Acceleration Head With Vertical Pipe LineStarted by Guest_Sansan_* , 18 Oct 2024 |
