Difference Between "sprinkler System" & "water Spray F
#1 Attiq Ahmad
Attiq Ahmad
  • 30 posts
Posted 14 October 2009 - 10:35 PM
Hello all,
Can any body explain that what is Difference between "Sprinkler system" & "Water Spray fixed System"?
Attiq
#2 gvdlans
gvdlans
  • 619 posts
Posted 15 October 2009 - 02:31 AM
A sprinkler system has closed sprinkler heads. The sprinkler heads can be activated by heat, e.g. by melting of frangible glass bulb. The frangible bulb is disposed between the body of the sprinkler head and a valve so as to maintain the valve in a closed state under normal conditions. When the sprinkler head is exposed to a predetermined elevated temperature, the frangible bulb expands to burst the bulb. This causes the valve to be opened so that a stream of a fire retardant fluid (e.g. water) rushes from the outlet of the body. So only activated heads will release water.
A water spray fixed system has open sprinkler heads. When the system is activated (e.g. by flame detectors, or by manual activation), water is send to the open sprinkler heads and all heads in that system will release water.
Edited by gvdlans, 15 October 2009 - 06:44 AM.
#3 VikingUK
VikingUK
  • 86 posts
Posted 15 October 2009 - 05:03 AM
Hello all,
Attiq
You will probably find the biggest difference is the location.
Sprinklers indoors eg offices workshops labs
Water spray outside eg tanks pipelines vessels process areas
