On the subject matter, I read few articles on net including some post from Cheresources. Following is my understanding & conclusion.
The concept of self venting line is applicable to two phase flow, especially in vertical line, wherein gravitation force is considerable for liquid particles. Thus Froude number applies here. Following is the correlation for Froude number.
Froude Number = Inertial force / Gravitational force = V /gD
The Froude number is applicable when flow regime is “Annular”. In annular flow, liquid flows across pipe diameter, thus by creating annuli for gas phase to flow.
In case of vertically downward flow, liquid downward flow sucks gas phase.
In case of vertically upward flow, liquid particle are subjected to gravitational force which drags some of liquid in downward direction, which further sucks gas phase thereby causing localized two phase flow of other regime than annular.
In order to avoid this “back mixing”, it is necessary to have low superficial velocity, which can be ensured by ensuring Froude number less than 0.3.
Thus (Conclusion:)way of ensuring self venting in vertical segment is to increase the diameter of pipe so as to have Froude number less than 0.3.
(Conclusion:)For horizontal segment, the minimum recommended slope is 42 mm/m. However, I found detail calculation posted by Mr. Art..
Please confirm / correct my understanding.
Thanks & Regards
Edited by cea, 21 October 2009 - 02:18 AM.
