Design temperature of steam traced pipe line should be its saturation temperature at maximum pressure.
If am wrong pl correct?
http://www.cheresour..._tracing.shtml> supports tracing uses saturated steam, then your statement is OK.
Nevertheless another practice (of my work) specifies maximum operating temperature of steam as the design temperature of the traced line, which can be more conservative.
There are cases when available steam introduced to tracing line is superheated *. Even so, steam gets saturated after a while. For heat transfer calculations, steam temperature is accepted same as saturation temperature (normally not taking superheat into account).
So there must be not much difference between the two statements, especially for common cases of steam tracing.
*even if saturated steam is required, steam in transfer lines has some superheat to avoid condensation.
