Partial Vessel Volume Calculation
Posted 28 October 2009 - 06:22 AM
Can anyone give me a formula to use (metric please) Im using this one...
=SUM((392.75*(3030-A2)*A2^2/3030))+(5280*(SQRT((2020-A2)*A2)*(A2-1010)+1010^2*(ACOS(1-((A2/1010)/1010)))))
which is from....
v= (pi*r(3R-y)y^2)/3R which gives volume of both end caps (formula is for a spheroid but assumes both ends are one)
plus
v = L(((2R-y)*y)^2(y-R)+R^2*acos(1-(y/R)))
volume of partially filled cylindrical section
where
y = vessel level
R = radius of vessel
r = radius of arc of end caps
L = cylinder length
Ive tried for hours but I keep getting a negative solution anyone got a better formula ?
Posted 28 October 2009 - 08:03 AM
Formula works perfectly and if anyone wants to cut and paste it to an excel sheet here it is.
=SUM((((pi*r)*((3*R)-B2)*B2^2/(3*R)))+(L*(SQRT(((2R)-B2)*B2)*(B2-R)+R^2*(ACOS(1-((B2/R)))))))/1000000
you will have to put your own figures in for :
R = cylinder radius mm
r = elipse radius of ends mm
L = length of cylinder (not including elipse ends)mm
B2 is the cell on excel I used to enter the level (height of liquid in vessel)
dimensions are in mm and solution is in litres
Posted 28 October 2009 - 08:26 AM
Please ignore me I am an idiot, I divided the diameter twice..!!
VikingUK,
Another recent one & it is quite good.
http://www.cheresour...__fromsearch__1
Posted 28 October 2009 - 11:22 AM
[/quote]
There is a huge discrepancy from my sheet and the one you mention
my calculation is based on :-
V= (∏ r (3R-y) y²/3R) + L(sqrt(2R-y)y) (y-R)+R² cos¯¹(1-(y/R))/10^6
Where
V = volume in litres
y = level in tank in mm
L = length of tank (tan – tan)
r = radius of elipsoid ends
R = radius of cylindrical section of tank
Batch Adsorption: H/d Ratio For Vessel SizingStarted by Guest_Victor_process_Engineer_* , 28 Feb 2025 |
![]() Constant Volume Vs Constant Mass Flow Of Centrifugal CompressorsStarted by Guest_panoska_* , 18 Nov 2024 |
![]() Partial Volume Of Bi-Lobe TankStarted by Guest_bangzhuqiao_* , 16 Oct 2024 |
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
