Unit Conversion
Posted 29 October 2009 - 10:52 AM
I simulated a cryogenic nitrogen rejection column in Aspen (peng-robinson package) with the top vapour product, nitrogen and helium leaving at -195C and methane in the bottoms leaving at -162C.
I obtained a stream table of results, and i needed the densities of both the vapour and liquid stream (pv and pl) to calculate a column diameter.
However, aspen has given me pv and pl in units of kmol/cum, and i need to convert that to kg/m3. ive never come across kmol/cum before, any ideas on how to convert the units?
my pv is 0.16 kmol/cum, and pl=26.38 kmol/cum.
any help would be appreciated...
thanks!!
Posted 29 October 2009 - 11:05 AM
Posted 29 October 2009 - 11:07 PM
thanks!!
Dear redapples,
It seems you have forgotten to specify the units of density, so Aspen has taken the default units of kmol/cum.
Just select the units as kg/cum in the Units column opposite to the physical property that you have selected. It will solve your problem.
Pavan
Edited by kpavan, 29 October 2009 - 11:08 PM.
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
![]() Vacuum Getting Disturbed Periodically In Vacuum UnitStarted by Guest_aka28_* , 08 Oct 2024 |
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
