We have a vessel containing 85% acetic acid in water at 305 F . Occassionally, chlorides enter the system. Corossion of the 317ss base material results. In areas where the base metal has thinned we have built up the metal by welding 2205 material on it to the required thickness. The weld overlay is holding up against the attack even as the 317SS in other area continues to thin. However, 2205 coupons placed in the attack have thinned at the same rate as 317SS. Does this make sense that a weld overlay of 2205 does not thin, but a plate of 2205 does ?
Weld Overlays
Started by AKsrey, Nov 04 2009 02:07 PM
Posted 04 November 2009 - 02:07 PM
Posted 06 January 2010 - 02:34 AM
hi AKsrey
i think this is really a weird case. between the 2205 overlay and plate, the effect should be the same. if i were you, i'll check whether the material is correct then only i'll go to the thickness. probably the plate thickness is lesser than the overlay so the overlay looks OK without corrosion.
Weld Overlay Vs Explosion Bonded CladdingStarted by Guest_Abdelilah_* , 11 Nov 2018 |
Strength-Weld Tubes To TubesheetStarted by Guest_juche_* , 17 Jun 2015 |
Weld Joint EfficiencyStarted by Guest_AmoorSaleh_* , 03 Sep 2014 |
Strength Weld HelpStarted by Guest_WilliamN_* , 20 Aug 2013 |
Flat Face Flange Weld Neck For Diesel PipingStarted by Guest_Athan_* , 19 Aug 2013 |
