i have a question concerning a fuel gas compressor for a Power Plant.
This is my first time in compressors so, waiting for a reply to a request of offer submitted to a manufacturer some days ago, I would like to understand more in order to be able to comprehend what the manufacturer will say to me.
The fuel gas will be compressed in order to enter a turbogas.
1) First, these are my input data:
-fluid: natural gas (principally methane)
-flowrate: 8750 kg/hr
-specific gravity: 0.6
-mol. Weight: 17.527
-Inlet pressure: 30 barg
-Inlet temperature: to be advised in order to obtain 70°C on outlet
-Outlet Pressure: 48 barg
-Outlet Temperature: 70°C
2) Using a spreadsheet taken from this forum some months ago (sorry I dind’t remember the author, see attached snapshot of calculation), I obtained the required power=approx 205 kW. The suction temperature in order to obtain 70°C on the outlet should be 24°C approx.
Is it right my calculation?I don’t have experience on numbers concerning compressors, so I don’t know if this number is right or not.
3)In the hypotesys that the data are correct, what would be the type of compressor to be used in this case?reciprocating or centrifugal?
Thanks you so much
Matteo
