I have just recently started up 3 TEG Dehydration Units in a Gas Plant and have just noticed the color is getting dark on the unit which has been running for 5 months. Is this an indication of hydrocarbon saturation? I have increased the slip stream flow of the glycol through the Charcoal Filter to full flow from 10% flow. If I get hydrocarbons in the Reboiler I am afraid it will cause carbon to form. So what are the causes of the TEG color getting darker and what remedies from what I have already done with by increasing the flow to the Charcoal Filter?
Thanks, Jimmy
Teg Color Change
Started by jiramc, Dec 06 2009 03:06 AM
Posted 06 December 2009 - 03:06 AM
Posted 08 December 2009 - 02:20 PM
Your action is correct. How much is the differential pressure across the
filter. Is TEG getting dark over the time period or suddenly.
How frequently you are cleaning the solid filter.
Check the reboiler temperature not to exceed more than 204 DegC.
Regards.
Regards.
Posted 08 December 2009 - 10:58 PM
Thanks for the response. We are changing the Charcoal Canisters and the Particulate Filters. The gycol temperature has never exceeded 380F.
![]() ![]() How Does A Vsd Gas Centrifugal Compressor React To A Demand ChangeStarted by Guest_AlexNguyen_* , 08 Jun 2023 |
Change Of State Inside The Lng Heat Exchanger HysysStarted by Guest_Luna D_* , 15 Mar 2023 |
How To Change Saturated Steam In Dry Steam In Heat ExchangerStarted by Guest_Orzelgorskiego_* , 13 Nov 2022 |
Flow Change With Delta PStarted by Guest_james.corrobro@gmail.com_* , 15 Aug 2022 |
Pressure Change Of Air In A VesselStarted by Guest_panoska_* , 05 Mar 2022 |
