I got a problem to complete which requires me to use Aspen. I have Aspen Plus installed and working correctly. This is a part of my project:
System Parameters
The total length (L) of pipe in the system is 100 ft.. The change in height (Δz) between the inflow point
and the point where the fluid exits the system is 8 ft.
The pipe is copper tubing with an actual internal diameter of 1.0195 inches. Assume that a scale 0.25
mm thick has formed on the internal surfaces. A friction loss factor of KROT=3.0 can be assumed for the
rotameter. Use Aspen to determine the physical properties.
The pipe system diagram has a number of different types of valves and bends. I'd like to know how I go about calculating the physical properties using Aspen (the friction factor or more). From there on, I can figure out how to solve the rest. Can the K-values for different types of valves and bends also be calculated using Aspen? I can supply more information about the problem and the project pdf is the attachment.
I'd really appreciate if you could point me in the right direction. I am completely new to Aspen.
Thanks again for any help!
