do you have any idea what's the different between rectangular & circular impingement plate? is it something to do with efficiency of distributing shell side flow?
Thanks.
Posted 20 January 2010 - 04:16 AM
Posted 22 January 2010 - 01:23 PM
Plate Fin Heat ExchangerStarted by Guest_panoska_* , 16 Jul 2024 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Low Pressure Air Flows Thru Orifice Meter Plate QuestionStarted by Guest_sfhh_* , 24 Feb 2023 |
![]() Orifice Plate Measuring Flow Away From Calculated Value!Started by Guest_Fatema1987_* , 08 Mar 2022 |
![]() Discharge From Tank Against A Flat PlateStarted by Guest_raju.kct_* , 26 Jul 2021 |
