Edited by gayathri, 24 February 2010 - 12:24 AM.
Posted 02 February 2010 - 12:19 AM
Posted 04 February 2010 - 01:24 PM
Posted 05 February 2010 - 12:31 AM
Posted 06 February 2010 - 02:59 PM
Another reference for adsorption is G. G. Brown's "Unit Operations", Wiley 1950, Chapter 27 - Adsorption. Though I have no knowledge in adsorption, understanding is as follows.Service Moisture trapping from purge gas
Adsorber type Mol. Sieve 5A
Bead size 3 mm
Capacity 49 gm of moisture
Helium Flow 31.5 Nm3/hr
Operating temperature 30 oC
Operating pressure 0.12 MPa
Moisture content in purge gas 11.5 ppm
Size 200 mm dia x 250 mm height
Regeneration time 7 days
Regeneration temperature 250 oC
Regeneration heater 1 kW
Insulation type Hot
Quantity 2
Edited by kkala, 06 February 2010 - 03:14 PM.
Posted 14 February 2010 - 10:40 AM
As said before, I had no knowledge on adsorption, even though I see G. G. Brown (ref of 6 Feb 2010 post) treating its simple cases more or less like distillation (diffusion not detected). But I understand now that you have specified everything by yourself (you write "no input data s given") and I would like to express few comments from an ignorant viewer, that may or may not be useful.As for now ive calculated the
Amount of adsorbent required(by using adsorption isotherm data from literature)
The volume of packed bed,its height,diameter,residence time of purge in the column.
What should be my next step....the time required for regeneration has already been calculated.
How to proceed with the regeneration in temperature swing adsorption process??
CAn I proceed with HTU and NTU calculations??
![]() Heat Exchanger Network DesignStarted by Guest_Kakashi-01_* , 21 Feb 2025 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
Performance Testing Of Air Cooled Heat Exchanger In Off Design ConditiStarted by Guest_go-fish_* , 09 Dec 2024 |
