ive just started using Pro II after using HYSYS for a year now, my question is there something in PRO II equivilant to the Adjust and Set tools in HYSYS?
thanks in advance
Adjust And Set Pro Ii
Started by man_in_black, Feb 02 2010 04:42 AM
Posted 02 February 2010 - 04:42 AM
Posted 02 February 2010 - 09:44 AM
I'm sorry to not be more helpful, but I did the opposite translation about a year and a half ago. I know that ProII has similar "control" functions though I cannot recall the names of the functions and I don't have access to ProII now. Good luck. It is there and it works quite similarly.
Posted 02 February 2010 - 11:24 PM
I used Pro/II quite a bit up to 5 years ago, much has moved to dustier corners of my memory.
Pro/II has something called a DEFINE statement, that works like a SET in Hysys, but it is not a separate unit operation, it is just part of a unit operation specification. Also, it has CALCULATOR and STREAM CALCULATOR blocks that can sometimes be used, but to copy streams (like a Balance operation) you would use a REFERENCE STREAM, near the beginning of the input file.
Then, Pro/II does adjust-like things with SPECIFY and VARY statements.
Best thing to do is get a hold of a keyword input manual, that describes everything you ever wanted to know about Pro/II but were afraid to ask.
You will have noticed that my responses exclude the use of Provision, I have very limited experience with that, and could easily accomplish what I needed using the keyword input, plus I found things could be set up quickly and easily using a keyword input. Frankly, when I started using Hysys I was actually looking for some sort of keyword mode, to facilitate checking and understanding other people's simulations.
Posted 16 February 2010 - 10:11 PM
thanks in advance
U can use controller. i think it has the same function.
Adjust Function In Pro/ii Just Like HysysStarted by Guest_mychemicalromance0425_* , 25 Apr 2022 |
Adjust Function HysysStarted by Guest_Daniel89_* , 09 Mar 2022 |
How To Adjust Pid Values In Dcs For Steady OperationStarted by Guest_krasygan_* , 16 Mar 2013 |
![]() How To Adjust Flow In Dynamics ModeStarted by Guest_mona naser_* , 13 Feb 2011 |
Set-adjust & Balnce In ProiiStarted by Guest_mohammad reza_* , 26 Jan 2008 |
