I have a piping and metering system that contains 50% NaOH. It must be insulated and heat traced to keep it form freezing during cold weather. Typically aluminum is used as the protective jacket material for the insulation. However, a NaOH leak would dissolve the aluminum. Do you know of a better material to use for the insulation jacket?
Insulation Jacket For Caustic Soda Piping
Started by torch55, Jan 20 2005 08:40 PM
No replies to this topic
Posted 20 January 2005 - 08:40 PM
Maximum Velocity For Piping In Fire Water Distribution System (Fire WaStarted by Guest_applepe_* , 06 Sep 2024 |
Pressure Drop In PipingStarted by Guest_Jaldhipatel_* , 05 Jun 2022 |
![]() Pressure Loss In Piping - Cooling Tower-Shelltube HeatexchangerStarted by Guest_Alneto_* , 29 May 2024 |
Hot InsulationStarted by Guest_Lyne_* , 14 Apr 2024 |
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
